I have been working on a lot of 26's lately, their construction may be similar. There are 4 main pieces: hull, deck, and two liners, the tub and the overhead (my names for them). There is clearance in some places between the liners and the hull or deck- other places have no clearance at all (like around windows). If you have a 1/4 inch or so, you can install an item called a rivnut. If you design your item to have enough rivnuts installed, it can be securely attached to fiberglass. I have been installing a lot of items with *8 and *10 button head screws into rivnuts. A rivnut tool is available at harbor freight, but the rivnuts are not the best quality. I forgot to say that the rivnuts are a blind fastener, ie: you do not need access to the back of the panel to install them. I have fabricated and installed shelves on the liners and interior dome lights on the overhead with total success. I have a lot of experience with velcro. It's attachment will need an adhesive that is messy, and believe it or not, over time the velcro is stronger than the adhesive. The velcro will eventually pull off leaving a messy area and a failure to support, usually when you most need it. My only application for velcro is sewn to fabric, I am done glueing it on anything.Fiberglass is glass. Screws into fiberglass will loosen over time and crack out. You can start with a small screw and work your way up progressively to bigger screws until you have a hole big enough for a rivnut, which you should have installed in the first place. YMMV
