Wood floor for Sea Eagle tender
Aug 13, 2012
27
Hunter 34 Worton Creek Marina, MD
I was wondering it there would be any downside to making a wood floor for our Sea Eagle PVC tender.
Perhaps the hard floor would make the bottom more vulnerable to puncture?
Any comments would be appreciated.
Nov 6, 2006
10,054
Probably would (wood?) be more likely to abrade/puncture if run aground.. the concern might be the edges and corners of the wood floor, where it contacts the tubes. if the wood edges are smooth and rounded and the fit is tight enough from letting the floor pop out but not so tight as to tear the side tubes, probably fine.
May 24, 2004
7,164
CC 30 South Florida
We had a 12' Zodiac that came to us with no floor boards. We made 4 pieces of 1/2" plywood and rounded all edges with a router. We soon realized the need to interlock the pieces to keep them from sliding out of place and on top of each other. We decided on small hinges which would permit folding the boards but would horizontally keep them in place. We used it for a couple of years and then passed it on. Never had a problem with chaffing. Oh, we stained, treated and poly protected the wood.
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
Use leather or webb strapping for hinges. Much easier on the boat and you. Chief
Apr 27, 2010
1,279
Hunter 23 Lake Wallenpaupack
I fabbed a wood floor for my cheap Dick's Sporting Goods inflatable. Used leftover wood intended for wall paneling, that has the tongue-and-groove edges. I found a scrapped piece of aluminum bar in our boat yard, cross section shaped like an H, about 2 in high and 1 in across. That is bolted to each wood slat down the center line. I also rounded the edges of the wood where it slides under the side tubes, and stained it.
The "H" piece down the middle has the disadvantage that you can't fold the floor, but it isn't that big anyway. That piece is obviously on the top side of the floor. One advantage is that I took some pink foam planking used for insulation (also scrap I had) and made a bench by gluing a few planks together with urethane glue. The topmost plank is a bid wider than the others to form the seat. I cut a groove into the bottom plank and it sits neatly over the H bar, holding it in place. Works very well to keep my seat pants dry.
It is pretty stable when I step out - no Zodiac, but this is just to row out maybe 200 feet to the mooring and then leave it tied there while I sail.
