Wood bottom Highfield dinghy
Oct 28, 2021
55
Beneteau 323 Wiarton
Have just purchased a 2017 Highfield rollup dinghy and discovered that the hard bottom is not aluminum (as I expected) but wood. Has anyone had good experiences with plywood bottoms? I imagine that after a season or two of good use, the wood will be swollen and rotten... should I resell or is it possible to buy a replacement aluminum floor? Any advice welcome.
May 27, 2004
2,057
If you leave it in the water and in the elements the floor will eventually delaminate/rot.
Assuming its a PVC roll-up, UV will degrade the rest in about two years.
You could get a cover for the dinghy. $$$
You could take out the floor and put on 4 coats of epoxy and 2 coats of UV resistant varnish. $$
OR...
You could Sell It as is and get a hypalon rib w/ aluminum floor.
Your money (and time)... Your choice.
Apr 5, 2009
3,170
Not a Highfield but I have a Zodiak with a wood floor that I have been using since 2008 and the floor is fine. I have taken care of it and do not leave it in the sun and weather any more than I need to. I role it and store it at home between cruises.
Wood floors are very common and work and last well. Use and care determine how long the parts will last. The plywood schooner I lived aboard in the '70s is still sailing out of Key West today.
-Will
Likes: jon hansen
Dec 29, 2022
2
Privilege 435 At Anchor
Friend of mine had a West Marine wood floor roll up and the floor only lasted two seasons. He got new boards from Home Depot and covered in epoxy as ggrizard mentioned.
Apr 5, 2009
3,170
The big downside to wood floors is they are much harder to set up (at least mine is). My previous boat had a high-pressure air floor, and it was so much easier to collapse and put into a bag. We went with a wood floor for the replacement to save about a boat-buck. We have regretted it and the next will be another air floor.
I have an airfloor. There is an insert 3 piece fiberglass floor that sits on the air floor.
It helps with maintaining the boat shape. It collapses to a rolled up raft with extra parts. The raft came with the boat. No idea how long it will last.
I keep it rolled up until needed and out of the sun.
Inflation is easy with a powered air pump, and the supplied air pump.
Sep 17, 2012
110
Morgan 383 Fairhaven, NY
My buddy's air floor peeled off his WM dink, FWIW.
I replaced an Achilles wood floor with Starboard. Worked great, but I just looked at Starboard pricing. Wow!
  • Wow
DArcy
Feb 11, 2017
1,773
Islander Freeport 36 Ottawa
I possible alternate material for a wood floor could be Coosa board. About double the price but it is not prone to rot and is "At least 30% lighter than a comparable piece of plywood, but with superior stiffness and strength"
