Tracing Starter Probems
Nigel Calder's book will walk you through the trouble shooting process. Your problem can come from numerous sources. Normally, you troubleshoot from least expensive-easiest to fix, to the big ticket solutions. On the lower end of that process, are loose connections, at the expensive end, shorted coils in the starter.I'd check the wires and connections to the starter itself. If they are loose, you could get intermittent starting. Assuming all of the cables from the battery to the starter (I'm referring to the heavy, 4 guage or so, battery cable), try this. Connect a short little jumper wire from any positive supply of power, to that little tab on the starter solenoid. That's right next to where the big battery cable fastens on the starter solenoid, and is where the starter button wires to. (You can also use a big screwdriver, carefully shorting from the positive battery cable post on the solenoid, to that tab. But careful! Lots of amps at that big terminal. Wear protective goggles!) If nothing happens, plan on pulling the starter. You have either a bad solenoid, stuck or warn brushes in the starter, or burned field coils in the starter. If you hear a click, but the starter doesn't turn, you know the solenoid is probably okay. Assuming batteries are in good condition, with good wires, you have narrowed the problem to the starter (brushes and field coils again). If you get nothing but a litte spark when connecting that wire to the starter solenoid connection, figure on removing the starter. Then take it to an alternator/starter rebuild shop, and hope it's only brushes. From the information you have provided, it is really guessing to try and further diagnose your problem right now. But my best "guess", is either stuck or worn brushes, a short in the armature of the starter, or shorted field coils. The intermittent prior starting kind of suggests the brushes answer, but not concusively. It has to come off for any of these repairs anyway. Oh, and rebuilding it should cost well under $100.Finally, if all this trouble shooting sounds like too much of a pain, just remove the starter and take it in to the shop. You should be able to take it off in about 10-15 minutes. They can test it off the boat easily. WARNING: Disconnect battery cables before removing starter or starter cables. Big amps, big sparks, can melt wires and do damage quickly! Good luck.Again, pick up Calder's book!
