Won't hold water
Bill Jones
I have a 1994 40.5 and the aft head will not hold water when you pump it in. The water slowly drains down the head. It's not leaking out of the system, but why does it not contain the water? Also, when you pump the forward head, the aft head "gurgles". Any help is appreciated. Bill Jones s/v Bardi Sea
C
Claude L.-Auger
Joker Valve?
Peggy is the real expert, but my first thought would be to replace the joker valve. If it leaks, it will let the bowl drain. It does drain into the system and will let the water seep into the hoses going to the tank. It might also cause the gurgle as it lets air out when you pump the forward head. While you're at it, why not service both heads. They're the same age! Go to the head mistress forum for instructions and info. Good luck
Peggie Hall/Head Mistress
Marine toilets aren't supposed to hold water
A manual marine toilet brings water in on the upstroke and pushes it out on the downstroke...there's no way to bring water in and keep it in the bowl unless you pour it in with a cup. The most that should be left is about an inch in the neck of the bowl, which will seep out. So will any water poured into the bowl with a cup...it's only a matter of how quickly it does it. When the joker valve is in good condition, it seeps out. Any faster, and it's time to replace the joker valve. A joker valve is a one-way valve...it isn't supposed to prevent water from leaving the bowl, it's only supposed to prevent backflow from flooding and overflowing the bowl. A brand new joker valve will sometimes close tight enough to prevent water in the bowl from seeping out, but that only lasts for few flushes. A marine toilet CAN be jury-rigged to hold water, by removing the joker valve and installing a high loop in the discharge line so that flush water between the bowl and the top of the loop runs back into the bowl. It's fairly common on houseboats (those floating mobile homes on barge hulls that litter the inland lakes and rivers), but I can't imagine doing that on a sailboat 'cuz all the water in the bowl would slosh out all over the head when the boat heels or in heavy seas. That's WHY marine toilets aren't designed to hold water...they're designed to be used on boats, not in condos. As for why the aft head gurgles when the forward head is pumped, without seeing how your sanitation systems are plumbed, I can only guess. Two toilets that far apart SHOULD be two completely separate systems--as separate and individually complete as they'd be on two separate boats. There are maximum distances that any toilet can pull in flush water or push waste, and the distance between fore and aft toilets is WAAAY too long for both toilets to share ANY plumbing, holding tank, or treatment device without causing all kinds of problems. But it sounds like a previous owner may have run them both to the same holding tank...or worse yet, connected 'em both the same intake thru-hull. I strongly suggest you do two things: get the owners manuals for your toilets from the mfr and read 'em. If they haven't been rebuilt in the last couple of years, it should be done (and while you're in there, lubricate both pumps with a good slathering of SuperLube). Otoh, depending upon what make/model they are, it may be just about as cheap to replace 'em as rebuild 'em. The article in the HM forum reference library (on the forum homepage) will be useful to you too, when it comes to maintaining both your sanitation system(s) and your fresh water system.
A
Arthur Boas
I know why. Peggy, do you agree?
You have a vent restriction, which is pressurizing the system. If you look at your vent, it has a small screen, which is probably gummed up. Remove it, and discard. I would think you have some odour down below beacuae of this by the way.
Peggie Hall/Headmistress
Don't think so, Arthur
Backpressure from a blocked tank vent would prevent the bowl from draining...it wouldn't prevent the bowl from holding water. Read my reply to him... However, if--God forbid!--both toilets are connected to one holding tank, you MAY be onto something when it comes to why the aft head gurles when the forward head is pumped. However, if the tank vent were blocked it should also happen in reverse too--the forward head should gurgle when the aft head is pumped.
A
Arthur Boas
Peggy, Both heads are on one tank
Peggy, I have a 40.5, and indeed, both heads feed one tank. That is why I'm confident the gurgling is caused by the vent. I am sure that if the owner tries this in reverse, the other head will also bubble.
Bill Jones
Vent Restriction
Where is the vent? I am mechanically illiterate so treat me like a child. Bill Jones
