Combiner
Guys, this is a combiner. It senses which battery bank is being charged and connects the house bank and start banks together when a charging source is present. It does not carry house battery bank or starting battery bank loads. The charging source is not important but could be the engine alternator (most likely) or solar, wind, etc. What the 6 feet of #6 wire does is limit the current flowing through the combiner (between battery banks) to a level that does not damage the combiner. Yes, the combiner DEPENDS on the voltage drop and slight resistance of the #6 wire to protect itself from destruction. Here is the scenario (assuming the charging source is connected to the house bank): 1) Engine is started. Combiner is "open" meaning the house and start banks are separate.2) Engine starts and runs - the combiner senses the charge voltage and closes, once the house bank is recharged, connecting the the house bank and start banks together, charging both. 3) When the combiner closes, there is a momentary inrush of current from the house bank through the combiner to the start bank. 4) The 6' length of #6 wire protects the combiner from excessive current.5) Finally, house current and starting current does not flow through the combiner, only charge current from the charging source. Thus the #6 wire is more than adequate. It never carries anything but charge current between the banks.6) When the engine is shut off, the combiner senses the absence of charge voltage, and opens, separating the house and start banks thereby preventing start bank from being discharged.7) When I installed one of these on my boat, I used 2 6' lengths of #6 wire - one from the house bank, and one to the start bank. Works like a charm and is pretty idiot proof
Hope that helps,RodneyS/V SashaySF Bay
