With or with out water ...
Jeff
I have a vacuflush system on my H380. I am only able to use my boat on every third weekend and if I leave water in the bowl when I’m gone, I get mold and hard water deposits. Should I leave it wet or dry? What would you suggest to remove the water deposits I have now, without damaging the surface of the bowl?
Dec 2, 1997
9,011
- - LIttle Rock
Leave it dry, pump off, vacuum relieved
Try white vinegar to remove the hard water deposits. If it doesn't work, it's safe--as far as the porcelain bowl is concerned--to use anything you could use at home. Just don't flush it.
Jeff
Thank you Peggy ...
Thank you for the advice re cleaning ... any advice re the wet or dry issue?
Jeff ...
OOPS!
Sorry, didn't see the forrest for the trees. Thank you ... Jeff
