Rob Rich
Hey all - Quick question on wiring. I found some very foul wiring aboard my C-27. After clearing most of it up, I ended up adding a couple of devices (radio and fish-finder) to my "cabin" circuit, which handles my cabin lighting fixtures (4).My quesion has to do with how to properly connect the positive and negative wires of multiple devices into a single circuit. My current configuration for the "cabin" circuit involves a single red wire that runs to the fuse/switch panel (positive)and a black wire that runs to the engine block. I took new red and black wires (12 guage) and stripped a small section of insulation off of them and attached the appropriate neg and pos leads from the radio and fishfinder to the "cabin" power leads. I insulated them with liquid electical tape and later standard electical tape as a temporary measure. This has worked fine for the past two months, but I want a cleaner, more permanent fix. What is the best method for putting three devices (in parallel) on one circuit? And yes, I did up the fuse amperage appropriately to accomodate for the increased load.Thanks for your anticipated responses!Rob
