Margaritaville
I am going to need to run some addition wires up in the pedestal. As i understand from looking in the archives this has to be done by removing the cover that is over the quarter berth. If there is any water in there does it drain down the rudder post tube? Any suggestions how to lower the cover without stressing it or causing any breakage? How much room is there in the pedestal? I need to run a 12volt pwer lead and another small cable in there for a supply video feed(Don't ask unless you really want to know)Thanks As AlwaysPaul
