The rewiring/upgrade on my 86 31' is nearly complete, thanks to lots of help from the forum. I encountered a puzzle.
1. The DC panel has a single pole switch for the bilge pump, and an old style glass AGC fuse accessable in the front of the panel, with a single male blade connector on the rear. I believe the fuse is supposed to protect the bilge pump/float switch circuit, but cannot figure out how or what the wiring should be to accomplish this. I have a simple wiring diagram of a pump/switch circuit, but it uses an inline fuse in the main power source.
2. I replaced a dedicated bat charger with a Freedom 20. I would like to move the single pole switch for the charger from the AC side of the panel to the DC and use it as an on/off for the fridge. I think is presently controlled by an ugly toggle switch added by the PO. Can it be used for this purpose?
3. The ammeter I have came with 4 wires and a 100 amp shunt. I want to take the reading between the alternator and cranking bat. I assume 2 wires go to the shunt, but are the other 2 used for turning the display on and off? Will the 100 amp shunt be adequate?
