Can someone tell me where the wiring for the port and stbd running lights is located in the area of the second window back on the stbd side?
I am planning to cut a hole for a holding tank pumpout fitting above the toilet. Not sure if the wiring was done the same in all the Vegas, Mine is one of the first series and there is a terminal block for the bunk lighting in the same area. Thanks, Colin, V-703 Isis.
