Wiring replacement
Dijobi
Jul 6, 2004
5
- - Shawnee Mission, KS
I need to replace the wiring from the forward running lights to the main electrical panel. Has any H34 owner completed this and how did you accomplish it. Thanks
Dijobi
Jul 6, 2004
5
Brad Hoff
The Entire Distance?
I had to replace only the wiring from the light to the through deck section. Are you sure you need to replace the entire length? The exposed section from the light to the deck had deteriorated and I just spliced below deck in the forward port berth and pulled the new wire through the railing using the old.
Brad Hoff
