How a single battery system can work
This is almost a "part 2" to my previous post.Lets consider how a single battery system can meet the "don't want to be left without power" desire.First off, install a high capacity battery. Without getting into the argument of what amp/hr means suffice to say that a 125 amp/hr battery will run things longer than a 75 amp/hr unit. Generally about 50% more usable capacity. Two 6 volt "golf cart" batteries in series are an excellent way to accomplish this (I heard they are closer to true deep cycle than the typical marine deep cycle/starting battery).Second, use a charge controller with your solar panel to remove the issue of overcharging or having to switch the panel in and out of the system. On the subject of solar - go for a 30 watt monocrystalline unit. Lots of power for a 26S and these are smaller than the previous gen ration 15 watt units. The one I use is only 11 X 26 inches and fits on the aft rail - with space for the swim ladder, BBQ and getting at the outboard.Third - the BIGGY. Use some of the cash you save from not buying that second battery, battery isolator, battery switch and buy a decent battery monitor!You can purchase units that monitor inflow and outflow and give a decent idea of capacity. They can warn you of reaching certain power levels and some can even take the batter offline until it once again reaches a certain charge level.Yes, you can do this with a voltmeter or a simple bar led monitor - but that old "manual" work creeps back in. If you want to be assured of having power - automate the monitoring process.Another advantage is that you get a true idea of your power demands and remaining capacity - and can plan power usage accordingly.When would I use multiple batteries? On a larger boat with higher power demands for sure! Then we're talking more than two batteries and a solar/outboard charge method.We make every weekend in the summer a 3 day affair plus several times for a week or two straight (can you tell I'm not retired - sigh). We have never run out of power - and we run the usual "trailerable" load of depth, VHF, GPS, Autopilot (usually when the OB is running), pressure water (low current draw system) and a reasonable amount of lighting in the evening (mostly LED).In my opinion it's all about simplicity and automated monitoring.One final bit to pass on. I have seen this for electric start outboards. Use the smallest motorcycle/lawn tractor starting battery for engine starting. Locate it as close to the outboard as you can - like in the aft locker on a 26S. As most outboards charge through the starting battery connections you'll need a charge isolator to ensure the outboard keeps it topped up while not allowing the outboard starter to draw from your house battery. Lots of ways to skin the cat - and this is just one persons opinion...Chris
