H
HENRY RAWLINGS
HELLO, I'VE TALKED TO THE LOCAL DEALERS AND THEY DO NOT HAVE A GOOD WIRING DIAGRAM ON THE ELECTRICAL SECTION. I REMOVED THE WIRING SECTION AND LABELED ALL BUT ONE WIRE. IT IS A GROUND WIRE WITH RING TERMIANLS ON BOTH ENDS. ONE SIDE IS ON THE CDI BOLT FOR GROUND. ANY IDEAL AS TO THE OTHER END GOES? HELP THANK YOU HANK Henry_Rawlings@email.msn.com
