Wiring from the Helm
Scoel
Jun 15, 2004
3
-Hunter -386 Winthrop, MA
I have a 2003 386 with a Raymarine C70 chartplotter at the helm, radar, autopilot, ST60 wind, speed and depth. I wanted to connect AIS and DSC at the electical panel where my VHF is located. The chase hole at the base of the pedestal is so full of wires that I don't think I can get another one through let alone the four for AIS and two for DSC (all 18 AWG). Can anyone think of a solution or work around?
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
If you are talking about the hole through the boat, just drill another one. I had to for all the wiring I added.
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Your Pain
Same thing on my 2007 H-36 has all the bells going through the one available stainless pipe but I was able to add one more small wire with grease and that was it and that's why I dare not try to add anything more and really impossible with all the wires already in the pipe.:eek:
The only way is to run wires on the outside with maybe a nice tube and try hiding it but thats it for sure and going down under the floor not a problem,good luck if you find a way let us know.
nick
BLIGHT
Feb 10, 2004
93
Hunter 35.5 Middle River Maryand
I noticed that you have two pipes coming from the deck are both filled?
Bob
Oct 29, 2005
2,366
Run a 3/4"-1" SS tube along the side of the pedestal pipe. Make a hole on the instrument cover for cable entry and cut a slot (not a hole) at cockpit floor cover (this cover is for the steering arm area) so that the floor could be remove without removing the tube/wiring. Stand-off the tube from pedestial pipe with home piping stand-off brackets. Dress the cables at both ends of tube with flexible plastic conduit (white color) and gormet. It'll look great.
Hunter 37 C sloop Punta Gorda FL
All of the wires at my helm go up thru the pedestal. Compass light, wind speed, power and A/P compass wires stop there. instrument wires go out of pedestal thru a conduit up to DF/ boat speed combo from Raymarine.
Project this summer to add a tall crash bar, single lever throttle/shifter from Edson and a nav pod. Will have Fuse block/ negative strip in nav pod, so only one power wire from "instrument " breaker on panel. DF wires and W/S wiring will probably continue up thru pedestal and conduit to nav pod. Throttle and shift cables will go up starboard leg of crash bar.
