I am installing two 90 watt solar panels and are confused with the wiring connections to the two house batteries. They appear to be wired in parallel but the positives from each house battery are separated {to the selector switch?}. I have connected the negative from both solar panels to the negative {negative terminal is strapped on each} of the house batteries. This part is correct.
The positive from the solar panels goes through a controller and the positive out to the postive of the batteries goes where? The positives are separated, not in parallel as you would expect. Also the sensing wiring also needs to be terminated on the negative {common} and the positive. Which positive?
Can anyone shed some light on how to wire correctly? The battery selector switch is the House 1 or House 2 with a switch on the bottom for 1 or 2.
