Wiring for a 3 wire bilge with built in float, from a 4 wire bilge pump with separate float switch
Mar 16, 2018
35
Catalina 310 202 Carlyle, IL
Aloha, I'm replacing the bilge pump in my Catalina 310 that has two wires (brown and black) and a separate float switch that has two wires, both black. The new bilge has the float switch built in and has three wires, brown, white/brown and black. The switch on electrical panel has both automatic and manual positions. Any advice on how to wire this new pump is appreciated.
Feb 21, 2010
350
Beneteau 31 016 St-Lawrence river
« If all else fails read the instructions ». However, brown should be positive for manual and white/brown postitve for automatic. Connect brown to manual (or your existing brown) brown & white to automatic and black to the negative bus. One of the two black wires going to the float switch was assuredly connected to automatic; you can connect this « live » wire to your white/brown.
  • Helpful
Likes: ggrizzard
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
You described the wires on the devices, I think, but not the wires that come to the bilge from the pump switch. Can you comment on those?
Also, can you look at the back of the pump switch?
Mar 16, 2018
35
Caboteur,
Thanks for the response. If there were directions, I'd certainly read them.
