Battery Circuit
This is a good discussion to jump in on. Our 290 was delivered with the standard A-B switch and we generally start on the A battery, but can redirect from the house bank. We changed our B by running it through another A-B switch to isolate each of the two house side batteries. So far so good.The thing that nags at me is that the house banks are a longer run away from the panel than the starter battery. If I had my preference, each battery, including the starter one, would be protected with a fuse. However, I was told that the starter could impose too high a load to allow me to fuse the battery primary leads. Since the starter can run off of any of the three batteries depending upon the position of the switches...is fusing the battery cables actually impossible?Dan Jonas (S/V Feije)
