Wiring diagram for a H33.5
JST123
Jun 17, 2011
42
Hunter 33.5 Lake Ouachita
I purchased a 1988 Hunter 33.5 in May. I did not recieve any wiring diagrams with the boat and have not been able to find any in my internet reseach. I am down to one last wiring issue with the anchor light. I check the light and mast wiring during the transport and it checks out fine. Looking for some help locating a wiring diagram. Already tried contacting Hunter, no response. Does anyone have a copy?
Apr 11, 2010
969
Hunter 38 Whitehall MI
Check Hunter web site under our fleet. They have service manuals for a number of models. They are electrical schematics.
Jun 6, 2006
6,990
It is pretty much an up and down circuit. 12 volts up to the light and ground back down. If you have a steaming or deck/spreader lights they also will have 12 wires going up. their grounds may be combined though. normally the mast head has one ground wire and the spreader/steaming has another that are combined at the mast base in to the mast ground wire.
Apr 8, 2010
1,606
Frers 33 41426 Westport, CT
I may have something.... I got a manual with my boat that had some diagrams for many other models in it too, ill loom to see if i can locate an electrical diagram that may match your boat
JST123
Jun 17, 2011
42
Thanks, and yep pretty simple up and down circut. I checked this during the transport,with the mast down and wiring and the light are good. A little more information is the there is a direct short causing the switch/circut breaker to trip. I have swapped switches and checked the wiring behind the switch panel for the obvious. Now I am down to chasing the wiring from the swich panel to the mast step to try and find the short. nSo I was wanting to know the routing of the wiring. Some times there is only one way to do it, that is to just start and do it!
