Rick
We have a 1981 Yamaha 33 with rear engine. The boat acme with a Yamaha Owners manual, but I believe it's supposed to be for the front engine version.
I have two problems
The bilge blower has stopped working. I have checked an inline fuse near the engine control panel but it is fine. Some of the gauge lights have stopped working (I think). We have owned the boat since April. I believe I have located wiring to the bilge blower but I don't want to have to unscrew all of the aft bulkheads or remove the propane locker and skinny in. If a colour coded wiring diagram was available for the rear engine Yamaha 3 I would appreciate a copy.
I want to install a electric bilge pump. There is a fused switch for a bilge pump the wiring exits the panel and then leaves to various areas of the boat. I could try to run new wire (probably easiest) but was wondering again about a wiring diagram with colour code.
Thanks,
Rick
I have two problems
Thanks,
Rick
