Wiring bilge pumps
May 14, 2004
9
Beneteau 345 oxford, MD
Two pumps, one float switch, dpdt power switch. I want to have the option of powering one or the other, any advice would be appreciated
Mar 6, 2008
1,516
You can replace the switch to a rocker switch on-off-on easily available.
7,728
Alden 50 Sarasota, Florida
Assuming you want two to place at different levels, one float switch won’t work. If you are planning to put both at the same level, get one bigger pump. If you need two in different areas, you would be better served with two floats.
May 14, 2004
9
Redundant pumps at the same level - one centrifugal one diaphragm - overkill I guess - was trying to avoid two floats but can’t think of any other way
May 14, 2004
9
I feel like an idiot - as soon as I diagramed the circuit the solution was obvious.
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
Does your solution avoid single point failure?
Considering that 90% + the failures of a bilge pump circuit are in those (D%^^) float switches, I would say that would be the point that I would double up.
