This is ONLY A GUESS
but, if it's anything like my Catalina30, then this is what you probably have.The case of the starter is ground when connected to the engine. Therefore, and I only GUESS here, the other wires are +12. There is probably one connector that is a slip on connector and on a smaller wire, and comes from the starter switch. That goes to the slip on connector on the starter solinode. The others have a ring connectors and go to the starter motor stud. One is probably coming directly from the battery. Another one MIGHT be going to the ammeter (if you have one). Don't take my word for it, you need a volt meter to check it out. You also didn't say what color wires they are. Do a search for the Catalina 28 users group. They may have diagrams online, or you may be able to ask there.DO NOT TAKE ANYTHING I SAID ABOUT THE WIRING AS THE LAST WORD. CHECK IT OUT!
