Derek Rowell
I'm in the process of installing a separate starter battery (Optima) to complement my house bank (2 4D's). Engine is a Yanmar 4JH-TE. I will ultimately replace the Hitachi 55 amp alternator with a high output/externally regulated alternator, but cannot afford to do it all in one step.My plan is to wire the alternator directly to the house bank (suitably fused), and to use a Heart "Digital Echo Charger" to maintain the starter battery.Here's the problem I came up against: I thought it would be a good idea to keep all of the "ignition" circuitry (ignition key, starter solenoid, tachometer, engine panel, etc) associated with the starter battery, so that a depleted house bank would have NO effect on starting. However, when I looked at the electrical schematics in the Yanmar Service Manual I found that the alternator output is internally connected to one of regulator terminals (I think it is the "L" terminal), which goes to the ignition switch. This means that if wired as I proposed, the house and starter banks would be paralleled through the ignition switch and regulator as soon as the switch is turned on (even before the engine was started). Not a good thing - especially with a depleted house bank, when very heavy currents would flow!So, unless there is an error in the Yanmar regulator schematic, it looks to me as if all engine control wiring MUST be connected to the battery bank to which the alternator is connected (the house bank in my case). It could have been a costly mistake!I don't think the same problem would exist with an externally regulated alternator.
