Starting to install a Water Witch float switch, but unable to determine the best way to run wires to the panel box. All ideas are welcome, thanks for any and all help.
Where is the switch going to be? In the lowest bilge under the center table? You could take it out of the bilge up under the seat into the storage area and back along to the icebox, then back behind that up to the panel. Assuming your layout is the same as the 2000 311 I have...Starting to install a Water Witch float switch, but unable to determine the best way to run wires to the panel box. All ideas are welcome, thanks for any and all help.
make sure not to drill into the cooling coils of the fridgedrill hole through the base of settee then again at the side next to refrigerator?
I didn't do this work - the previous owner did - but he did run a wire from that area up to the settee area, drilled a hole through and into the storage area, and ran the cable from there. I can't remember if there is a gap or something near there, but you'd have to make sure the floor board doesn't crush the cable. If you go towards the stern right near the fridge, I was able to run something near the outside corner of the fridge and there's already a hole to pass things through.Steve, yes switch is going under the table. I tried to follow the bilge hose but could not get a flex able steel wire back to the panel box, to be able to pull wire through. Am I understanding correctly, drill hole through the base of settee then again at the side next to refrigerator? Thanks for your insights, craig
