Wireless Wind systems
Sep 10, 2012
228
Hunter 450 Gulfport, Florida
I have been reading about less than stellar performance from specific brands of wireless wind systems. Does anyone have experience or an ear for how the Garmin G wind stacks up. I have to replace mine and it sure would be nice to have less wire to run in my furling mast.
Dec 31, 2011
8
Hunter Legend 35 La Paz BCS Mexico
My mast top transducer got wiped out by a 200 kph seagull or just the wind during hurricane Odile last year. Since I am here in Mexico the final costs with replacement (no warranty), taxes, shipping and long waits on hold to Garmin, in the end cost me about $1000.
The replacement transducer sent would pair with the original Nexus WSI box. They then sent a new WSI, transducer at additional cost, plus more Mexican tax and the return of the first transducer. This new system came paired, but after it was installed it didn't read the speed/depth hull transducer or send it to the gauges. So more time on the phone and making up cables and reprogramming (with online help from support) from my laptop.
After three months and a grand it is up and working again. I enjoyed dealing originally with Nexus, but my list of vendors I'll buy from in the future is diminishing.
The original Nexus installation was very simple, but since my wiring from my first system was still in the mast I would have been better off buying a wired system.
Jun 1, 2009
1,851
Hunter 49 toronto
Wind system
It's no big deal to put in a mast cable. (See my prior posts)
Then you have a rock solid low cost wind system
Get the Raymarine st60+, or the new i60.
Aug 16, 2009
1,000
Hunter 1986 H31 California Yacht Marina, Chula Vista, CA
Yep, Jack. It's called the collection agency.
Sep 11, 2011
428
Hunter 41AC Bayfield WI, Lake Superior
I had st60, junk on both ends the gauge would not calibrate and the masthead was trash. Raymarine quoted over 600 to repair. I choose to replace all of my st60 instuments with an i60 complete set. ( so I did not need to change much wiring). Still had to send the i60 unit in for warranty after 1 season, as the unit would freeze if it was in direct sun. The face would warp and the needle get stuck until it cooled.
Given what I said, I still really like the i60, the way they look "modern" and the ability to feed the 7000+ AP. Wind angle steerage is cool and efficient.
Jun 1, 2009
1,851
Hunter 49 toronto
I60
The i60 is just a repackaged st60+ with STng interface , and slimmer bezel. So, from a reliability standpoint, should be same as st60+
I've never had any problems with the masthead, but I use the long wand version.
Actually, the electronics in the raymarine masthead are more robust that most other units I've seen.
They use a very slick circuit which has a rotation sending IC (used in automotive controls) simply coupled to a circular magnet on the vane. Very simple, and quite accurate.
I upgraded all my ST60+ heads to i70s, which are fabulous. But, I kept the St60+ wind guages. Essentially, as the i60s are the same, I didnt feel like replacing the 3 existing heads (1 at each helm and 1 over the companionway) units for what it would cost
Sep 10, 2012
228
Re: I60
I have been digesting information about the best way to proceed and likewise will be installing I70's. Raymarine does not make digital wind transducers as well as the tridata DST800 they must go through the ITC-5 Analog to digital converter. I had ST80 Masterviews and Raymarine tech support says that the installed transducers will not work and that is a surprise. I have decided to go with a wired wind sensor to keep things as simple as possible. At least they produce the i70 system pack. The transducer appears (looking at pictures) to be mounted in a inside extractable housing as are my other transducers and if they are identical in size would save me from hauling. Specifics seem hard to come by.
