Randall
I'm faced with some winterizing decisions for my 36 foot sailboat and would lke a little advice. The location is fresh water, southern Missouri. Boats are left in the water for the duration and while the surface may freeze "some", it's not enough to pull boats or use those deicers. But it can certainly get very cold from time to time. I don't want to just lock the boat up for four months. On nice days I'd like the option of going out even if it is a bit cold. I'm on a dock with AC power, so the batteries will be kept topped up. I'll winterize the fresh water system (the usual antifreeze), and will drain the hot water heater and head - guess I'll use a porti potti since there are no pumpouts in the offseason. But what about the diesel engine? I'd rather not go through the whole winterizing process each time I'm out. Any thougths would be appreciated.
