Winterizing Water System
Ducati
Nov 19, 2008
380
Boatless Boatless Annapolis
This fall I'm winterize the water system our boat for the first time.
I ran the water system until no water was coming out. Then drained the hot water tank (it has a drain faucet) Next I'm planning to open the two fresh water fill openings and pour in the West Marine (non toxic, but still has a bad taste) anti-freeze. Then turn on the taps and watch for the pink color to start running out (including from the hot water heater).
Am I on the right track? How much antifreeze (gallons) should I put in each fresh water intake?
Thanks
gpd955
Feb 22, 2006
1,164
Catalina 310 Cape May, NJ
Bypass the hot water heater. Don't make the same mistake I did last fall. It will take hours of filling and running fresh water through in the spring to get the AF out completely. Male sure it it drained and then bypass it. My last boat did not have a HWH so I winterized this one like I did that one and it was a nightmare recommissioning!
If theres not already a bypass set up in your system just disconnect the cold in/hot out hoses and couple them together.
7,363
Alden 50 Sarasota, Florida
Thanks
None (if you are referring to the the tank(s)). Just pump directly from your container of AF through your pump to all faucets. No need to fill tanks with AF.
Oct 13, 2007
179
Hunter 37.5 Plattsburgh
This topic has been discussed in length in other threads through the past years. Basically what has been said here is what many,as well as myself do, and I have never had a problem.
Oct 15, 2009
220
catalina 320 Perry Lake
I have always drained then by-passed the water heater and used a wet/dry shop vac to blow.suck the water lines dry. I do not put antifreeze in the fresh water system.
Jeff
Sep 29, 2008
195
Hunter 33.5 Carlyle Lake in Central Illinois
We never put the pink stuff in our fw tank. After running the system dry I access the line at the fresh water tank and blow out the system with a portable air compressor. I dial the pressure down to about 30 psi. I leave a short piece of garden hose permanently connected to the drain on my HW tank. I put the hose in the sink and open the petcock and blow it out also.
Oct 13, 2007
179
That winterizing kit from Weast Marine cited above will work fine. I made basically the same thing by going to a local hardware store 1 piece plastic tubing, 2 plastic fittings and unions. My cost was around $6.00
