P T
According to the manual you should disconnect the intake and discharge hoses, pour antifreeze into the bowl and run it through and into a bucket. I have the pressurized fresh water version. Disconnecting the hoses is really a pain. What about just running antifreeze from your freshwater tank through the solenoid valve, vacuumm breaker, then into the toilet and into the holding tank? This way you don't have to disconnect any hoses. And I already have antifreeze in the water tanks anyway. Thanks.
