I'm going to do my own winterization this year. After cleaning up the boat boy's spills and mess for the last few years, I figure I can do this better. I also want to avoid dumping gallons of antifreeze in my tanks and hot water heater. Read Maine Sail's excellent well illustrated treatise on winterization but I still have a few questions:
Feel free to school me on all the tips and shortcuts. Ever since I found out how ugly this "non-toxic" AF is to the Bay I'm trying to limit the AF discharge. Hopefully I can get it down to 15 gallons of glycol or less going into the water.
Thanks,
Gunni.
- Winterizing the heat pumps. Have two, fore and aft. They utilize a single seawater pump midships. Can I simply disconnect the raw-water pickup from the thru-hull barb, bring the hose above the pump, stuff it with a funnel/drill pump and winterize both heat pumps, or do I have to do each heat pump separately?
- Winterizing the freshwater. Do I open faucets and valves closest to the freshwater pump and start bleeding antifreeze, or do I start bleeding at the far ends of the boat (forward head, swim platform shower)?
- Winterizing the head. I have Jabsco traditional manual pump heads. I plan to disconnect the raw water intake, drop it into bottle of AF and pump it through. Then drop some AF in the bowl. Sound right?
Thanks,
Gunni.
