W
Wayne Estabrooks
Since I leave my boat in the water all winter, here in NC I wanted to know if the way I winterize the thru-hulls for the vanity and galley sink drains is sufficient. I read the winterizing stuff and archives. I pour some pink stuff (polypropylene glycol)down the drain, about 2 cups to displace the water that is in there and then close the valve on the thru-hull.The water in the harbor has frozen slightly some years but my guess is since the thru-hull are below the water line 12 to 18 inches, that they won't freeze. On the head intake, I remove the hose from the thru-hull and remove the little bit of water in the valve with a turkey baster. I put the hose in the pink stuff and pump it through the head. Haven't had any problems yet doing it this way. Thanks for your help.
