thanks to all for the suggestions and input. The guy hired to winterize the 3YM30 has gotten it done, and the rest will be postponed til spring. Oil and filters change already on the calendar then, and some electrical exploration in between, as previous owners have added some DC wiring and I want to explore what they did - un-switched powered TV antenna at the masthead for a TV that no longer exists, evidently un-switched radar power line up the mast but no emitter or display installed, carbon monoxide alarms all over the boat where fans belong, and old power and signal lines for a binnacle mounted chartplotter that was upgraded in 2021 just before we bought the boat, so now have extra wiring in the binnacle. Opening the breaker panels will be an adventure I'm sure. Will just add the engine panel to the list to check all the connectors and wiring for issues.
Thread drift question - I don't particularly like the push-to-reset breakers Hunter uses for a bunch of DC equipment in their factory distribution DC panels, would rather have proper breakers. Has anyone swapped them out? Issues? Concerns?
