Easier than it seems
I traded my 356 in this year on the 426DS. I had winterized the 356 the last two winters with no trouble.Before the haul out, run the tank dry using the water pump by opening a few faucets. Once the tank is dry, shut off the water pump circuit breaker. Open the drain on the hot water heater and let it drain on its own. Take the hoses out of the hot water heater and join them together. The fittings have a piece near the hose end that you push into the fitting to release the hose (or push the hose into the fitting and hold that peice near the fitting as you pull the hose out, sort of a reverse of intuition thing). Once you get the hoses separated from the heater you should be able to connect them with either a new female to female peice, or if you are lucky that piece may already be there as it was on my boat. Once you have joined the cold and hot water hoses and have bypassed the heater you can move on to running the RV antifreeze through the system. I bought a winterizing jug from Westmarine. It comes with a few miscellanious fittings, but you may need to buy a few more that adapts different sizes. Disconnect the hose that feeds the pressure water pump that is coming from the water tank and let it drain into the bilge. Take a hose piece and connect it from the winterizing kit tank to the input of the pressure water pump. Fill the winterizing tank with RV antifreeze (I went through about 6 gallons total, but only thre on this stage). Turn the water pump breaker back on and run the antifreeze through all faucets until there is no sign of clear water. Don't forget the cockpit shower! The hard part is now done.Next, shut the through hull for the head intake. Disconnect the hose from the through hull. A little heat may help in getting the hose off. Using the winterizing jug, run RV antifreeze through the head system (this assumes you have pumped out well). A few gallons of antifreeze is all that you need here. You need only be concerned with the lines, not the tank, if it is dry.Do the same with the engine if you don't trust the yard to do it. I had them do the engine just to keep the warranty stuff going. If you do the engine make sure you use the lower temp antifreeze!! If you have heat and air you do the same thing, oly using the heat and air raw water pump to pump it through the system.Once the boat is in the cradle run antifreeze through the sink drains and operate all through hulls a few times to get any moisture out. Use a turkey baster to get some antifreeze into all through hull ball valves and operate them a few times.Use a shop vac to get the water out of the bilge and then run antifreeze through the bilge system. Shop vac out any remaining liquid and wipe dry.That's it. I used four of the humidity traps from westmarine and they all stayed dry until late winter. I stopped in late winter / early spring to do my bottom paint and emptied them each time.Good luck.Email me if you want to get more info. Teetera@aol.comSteve AchtemeierWissota, Hunter 426DS
