M.E.B.
After reading this thread I changed my plans. I was going to put basically a stack of 2x4s on the bow pulpit to raise the mast upso that the tarp would drape better/more evenly. Instead I made a MEB (mast elevation board) out of 2x4 material. It sits kinda 'inside' the trailer winch (2x4 standing on end) (this is a h260 ). This required just a slight trim on the aft port side of the 2x4 to clear the small gear on the winch handle....at least I think it was the gear on the handle. Fits perfect. Then this piece of 2x4 goes up to about 4-5" below the bow running light, this allows room to lift the board from the winch without hitting the running light. Next I piggy backed another piece of 2x4 on the piece that sits in the winch FORWARD of the first piece and screwed it down with six 2.5-3" deck screws. At the top of this piece there are two short pieces ~8", of 2x4 screwed onto either side to hold the mast laterally. The mast sits in there perfectly too! The whole thing is five feet long plus the lateral supports, I tried six feet but that was too long cause the mast is articulating towards the aft and was too far aft. This is a great solution, it's a one piece thing, is easy to in/deinstall, the tarp drapes MUCH better, not to mention the top (anchor light) end of the mast is lower. For us the height of that end of the mast was preventing us from getting a covered storage spot cause it was 12 feet (or more) in the air, so now we will be able to get into a covered storage spot too! Next I am going to make a similar smaller one piece brace to place in the mast step for support in the middle.Tom M.
