Jim Bessinger
This year after hauling my H30 out, I decided to remove the raw water pump and replace the impeller this winter. At this time I tried to poor some rv antifreeze into the heat exchanger that the impeller supplies. I found that after blowing out the line, which didn't expell much water. the line would take very little antifreeze. Would forcing more in cause a problem, like backing up into the exhaust of the engine?Thanks Jim Bessigner
