I have a few questions regarding winterizing my H356 which has a Yamar 3gm30 diesel which is "Fresh Water" cooled. Does the same coolent which cools the engine also heat the hot water tank? If so, then all I need to do to winterize the hot water tank is drain it - right? Do I need to winterize the cold water supply to the tank? My boat has AC/Heat which has a seawater supply. My plan is to take that off the ball valve at the thru-hull and dip it in the bucket of antifreeze and run the AC for a bit. Will that be adequate?The engine instructions from Yanmar are fairly clear and shouldn't present a problem. The fresh water system seems pretty simple but with the addition of Hot water over what I've done before. I assume that I just run the antifreeze through the hot lines just like the cold - right? Why not leave antifreeze in the tank rather than drain it?Thanks for any tips.
