Don
This was the subject of a recent post which is timely for lots of us up north and I thought it might be worth revisiting because of the lack of good info on the utility of filling your diesel tank before winter sets in. As you might infer, I am retired and have lots of free time to devote to some pretty esoteric subjects.This info comes from other sources and I'll be happy to provide references if anyone is interested:The maximum amount of liquid water in air at the following temperatures:30C/86F 30 grams/cubic meter 20C/50F 17 grams/cubic meter 10C/13F 9 grams/cubic meter There are 28 grams per ounce, so 30 grams = 1.07 oz; 17 grams = 0.6428 oz.A cubic meter equals 264 gallons of liquid volume, therefore:A 200 gallon tank = 0.76 cubic meter.At 86F, an empty 200 gallon tank could contain 22.8 grams of water vapor, or 0.81 oz.At 50F, an empty 200 gallon tank could contain 12.92 grams of water vapor, or 0.46 oz.Note that this is the maximum amount of water vapor that a completely empty tank could contain, in neither case a full ounce of water.In order to condense water out of the atmosphere a surface must be much colder than the air. The problem for the condensation in tank theory is; how do we end up with a fuel tank that is much colder than the air? One way would be to have a very cold day that suddenly warms up dramatically, but when does this ever happen? The weather can turn cold very fast, but does not suddenly get very warm.Aluminum is second only to copper for rapid heat transfer properties; it will therefore adjust to atmospheric temperature changes quickly. Gasoline and diesel fuel, like water absorb heat and cold slowly. Thus one might expect to see sweating on the outside of a tank as the day warms up from cold mornings, but this doesn't occur.What's the point? It would appear that what you get after a winter of storing a full tank of diesel is a full tank of stale dieselIf there are any other folks out there with too much free time like me who care to comment or poke holes in the theory, I'd be interested. Don
