Bob,
I used tarps over a frame I built for my S30, I'm on my 4th year with the tarp, no tears or deterioration, here are my sugestions:
1. Tarps
2 tarps 1-16x20 mast forward, 1-20x20 mast back. I got mine from Eastern Marine,Newark DE. Buy SUNSHIELD HEAVY 6 OZ SILVER/BLACK
http://shop.coversuperstore.com/index.cfm?fuseaction=catalog.catalog&categoryID=255
2. Build your frame using 3/4 EMT
3. One continous center spine, bow rail to 2 ft past stern - use EMT 3/4-3/4 couplings.
(I made the double bend around the mast - not easy)
4. I used 6 bows.
5. At the spine for each bow, bend about a 8-10" piece of 3/4 EMT at appx 70 degree angle (you'll need a 3/4 conduit bender) to form the center connection from spine to each side bow leg. Drill through center connetor and spine and bolt together.
6. At the end of each center connector use a 3/4-3/4 EMT coupling for joining the bow legs to the center connectors (and spine).
7. Bend each bow leg just above life line stanchoin (all bends will be in same loaction on every leg). Diagonal bow legs will continue up to center connectors. Cut length to fit so that spine is the same height mast to stern an slopes down mast to bow.
8. Cut EMT diagonal braces (about 42-48") for each side bow leg. Flatten brace ends in vice and bend to fit. Drill through brace ends and bow legs, bolt together. Diagonal brace starts at 3-4" above base of each bow leg.
9. Use rubber tips at bottom of each bow leg.
Assemble completed Frame.
10. Install 2 pc. 16' strapping each side the entire boat length connected tothe frame above the top of the diagonal braces. Use 3/4 EMT conduit clamps and screws.
11. Pad each center connector to prevent tarp tears and wear.
12. Drape tarps short fwd and long aft of stays, silver side out. I installed grommets at vertical split and tied two tarps together. Custom fit splits for fore and aft stays. (punched holes in doubled or tripled tarp will work)
13. Use a short loop of elastic cord at each grommet to provide a means to withstand stretching due to wind.
14.Tie sides of tarps to each other, under hull, at each grommet loop. BE SURE TO USE SOME PADDING ON BACK SIDE OF GROMMET, otherwise you'll spend time in the spring removing the aluminum stains from your hull.
BobD
Boston
