Wing Nut for Rudder???
Daniel Lawrence
I have a H240, 1999. There is only a single plain nut on the bolt which is used to hold the rudder onto the boat. On my previous H19, there was a wing nut, which you could use to tighen and loosen the tension holding the rudder in place. On the H240, there is only the rudder line for the up and down position. I have to keep the line cleated when the rudder is in the down position and I worry about what will happen when I eventually run the rudder into something. When I go to my slip, the centerboard is in the up position and the rudder comes close to hitting bottom. When I recently saw a new H260, it had a single arm wing nut on it's rudder. Did I just not get the wing nut for my boat or is the H240 without wings! Any comments would be appreciated. Happy Holidays, s/v Endeavor
Dave Condon
Contact Hunter
Suggest calling Hunter and ask for Mike Thomas and tell him what you want and I believe he can help you on the big ole wing nut with handle.
Daniel Lawrence
Thanks!!
Dave, Gave a call and Mike Thomas said one should have come with the boat and he will be sending one out in the mail today. I thank you for your help and I will let Hunter Marine know how appreciative I am to Mike for his help. Happy Holidays, Daniel
