Concerning the windows, I just reinstalled the two large windows. I had no luck at all with the technique of installing the rubber into the frame first and then easing the window into the rubber. Even with 3 people, at some point or another the rubber was pushed off the frame. I tried the "rope" technique and that worked quite well. Were I doing it again I would leave an inch or so of overlap (extra length) of rubber seal and then when the window was about all the way in try to work that rubber into the frame.
I did find an extremely useful tool to be a set of plastic bicycle tire "irons", handy for easing the rubber onto the window particularly in the corners. My wife came up with that idea, both obvious and brilliant. I also used a lot of silicone spray and a spray bottle of soapy water.Nicholas H. Walsh P.A.
111 Commercial St.
Portland ME 04101
207/772-2191
Fax 207/774-3940
This email is from a law firm and may contain information
that is privileged or confidential. If you suspect
you were not intended to receive this email,
please delete it and contact us.
AlbinVega@yahoogroups.com
Sent: Tuesday, April 28, 2009 7:39 AM
To:
Subject: [AlbinVega] New file uploaded to AlbinVega
Hello,
This email message is a notification to let you know that
a file has been uploaded to the Files area of the AlbinVega
group.
File : /Window installation tips.doc
Uploaded by : clinton_edmonds clinton_edmonds@...
Description : Window seal installation instructions
You can access this file at the URL:
Yahoo! Groups
To learn more about file sharing for your group, please visit:
Regards,
