I have a leak in one of the longer fixed windows. The water was running down the inside of the cabin liner (out of sight) and coming out into the settie below during hard driving rain. 2005 H306.There are 10 small screw holes along the outer edge (from exterior side)on both windows (port and starboard), but no screws, just empty holes. Looks like they had some sealant dobbed in them but weathered out and can see some daylight. Good news - easy find on the leak. Logic is that there was/is suppose to be some type of screw securing the window in addition to the sealant. I noticed the similar smaller fixed window has two small screws with cupped washer and rubber gasket.I installed a similar set up on the window in question through the 10 existing holes, however the look is definitely not the stock look. Was there suppose to be some kind of flush finish or trim on the exterior to cover screws? Or are the windows just set with the caulking/sealant only? If so, why the 10 screw holes?Any feedback would be greatThanks!
