windows and handrails
Hey Ran-Dee, I'm going through the same sort of thing with an older O'Day 22 and have found out great info. from this site and other sources. I tried looking up your boat so I could get a good look at the windows to see if they are vinyl or have an aluminum frame and I couldn't tell. If they are vinyl and in rough shape, from what I've researched, you're better off spending the money to get new ones rather than trying to fix. If I'm wrong on that hopefully someone will chime in. But if they're vinyl and in good shape you may be able to get them out, clean all your surfaces really good, wipe the area of the boat down where the window needs to be sealed to the boat with acetone and the vinyl frame with alchol (I'm pretty sure acetone may eat away at vinyl and know for sure Plastic products don't hold up to it). When you're done with the cleaning you may have 2 choices. 1 being using some foam tape, about an inch wide, around the part of the window frame that will set up against the boat (the adhesive side will go up against the window frame). If this is the case get the window in and tighten down, you'll see some foam squeeze out around the outside of the window when done which you can trim with a sharp blade. The second choice is more time consuming and costlier but is a possiblity if need be. Find some 3m 101 marine sealant (don't use 3M 5200 because it is and adhesive that will make the job of getting your windows out at a later date close to impossible!!)and run a bead around the window opening on the fiberglass of the boat, enough to where you'll get some oozing of the caulk when you put it in and tighten it down. It would be a real good idea to run some masking tape, before permanant instalation, around the outside of the window opening, about an 1/8 of an inch gap above and around where the window will set permanently so clean up will be quicker and not as messy.Run your finger around the edge of the window and any extra caulk can be cleaned up with denatured alchol. If you have aluminum frames you're in luck because I've found some great info. and a possible supplier for the bedding material. Rudy at D&R Marine told me to look up Catalina Direct (he doesn't carry the material needed to re-bed windows) because many O'Days used the same windows as the Catalinas. Catalina Direct has the material, actually its a kit that has all of the bedding material and caulk used to seal the window to the boat, so I'll be pulling them apart and re-bedding them. Also, it is a chore to get the windows out, so if you decide to do so take your time and clean all surfaces then wipe down with acetone making sure you don't get the acetone on your windows if they're any type of plastic. As for re-caulking the outside of the windows, I'm assuming (which is not a great thing to do!), that the previous owner may have tried to stop the leaks by running a bead of caulk on the outside and if the caulk was silicone it will fail eventually no matter if it be marine grade or the regular stuff. Silicone just doesn't adher to fiberglass all that well. As for hand rails, I refinsished all my teak and will be sealing the holes with 3M 5200. You don't have to lay a bead down on the whole surface of the wood or metal, just put some in and around the hole where the screws penatrate the boat. Some caulk will ooze out so be ready with some denatured alcohol to wipe it up. This will save you caulk (3M 5200 is expensive stuff) and time.If you don't want to get as crazy as what I'm doing and want to get out and sail your new boat, try the caulking around the window again it may hold for a season or two, giving you some time to enjoy your boat and come up with a good game plan on what to do.Good Luck and Happy Sailing!Curt
