Window replacements for 28.5
Rick Swanson
I have been replacing the windows by taking the old ones in ( cracked)for a replacement by local fiberglass dealers. I now have cracks in both windows in different place for reasons I can not figure out. Does hunter have an outlet for 1988 replacement windows?
Dec 2, 1999
15,184
Mark Plastics!
Rick: Mark Plastics in Southern California can make some of the fixed port windows. You can call him at 909/735-7705. If you are looking for the opening ports, they are from Bomar/Gray and you can buy them at discount from Thrifty Mariner in Fl.
Mike Kenny
What adhesive are you using?
Perhaps the adhesive you are using is attacking the acrylic. When I replaced the leaking windows on my 89 H23 last year, one had been replaced before and the other was original. The previously replaced window had many small cracks and was noticeably melted where the sealant was applied (I don't know what it was.) The adhesive on the original window was amazingly pliable and the acrylic surface was not damaged. I called Hunter to find out what they used. Hunter advised it's Dow 739, an industrial Plastic Sealant/Adhesive. They said it was hard to find but I could buy it from them. I also found an alternate source at Neely Industries.
C
CaptJeff
Try the Thrifty Mariner
Check out the Thrifty Mariner, they carry all the older Bomar ports and windows and Hatches. Phone# is 813-390-7474 and www.thriftymariner.com
