Window rebedding
12
Hunter 33.5 Iron Mountain Marina, Degray Lake, AR
Just noticed a corner of a window on '93 33.5 loose. Is it time to rebed those windows? If so, what's the drill? The lexan (plexiglass) is still good, and I suppose will retain their curve if removed. This so? Thanks.
Philip
Oct 29, 2005
2,362
Don't have answer for you. On mine, a corner of the window lifted, letting in water. I filled the gap with 20 bucks Silkaflex 295UV sealant. Within a year it lifted and leaks. So I dig out some old sealant/compound and refilled with 5 bucks black RTV silicon (for windscreen) bought from car parts shop and haven't had any problem with that window for last 4 years.
-na -NA Anywhere USA
There is a difference of silicon caulks and I have used an architechual grade of pure silicon which I believe the rtv grade mentioned is. He is correct.
Dec 2, 1999
15,184
The product that has been recommended is the DOW795. It was what Hunter used originally.
Sep 29, 2009
12
window fix
Hey, thanks guys. I will try to patch using the stuff Hunter used; nearly 20 yrs. on the original's not too bad.
