Window Leak on 1999 H310
  • Thread starter Ralph Johnstone
  • Start date
Ralph Johnstone
I recently had a leak in an overhead window on our H310. I was not able to remove the acrylic (guess work) window due to the large contact surface area between the fiberglass and the window and so settled on a third rate job of just putting a new bead of Dow 795 around the edge of the window. It is only because of my devout religious upbringing that this thing is not leaking again. It sure ain't the workmanship that's kept it from leaking. Can anyone offer a procedure for removing these windows to do a proper job of rebedding the window ? As mentioned above, I have a landing around the windows of about 2" - 3" for the Dow 795 to adhese to. Lots of surface area to break away. I don't see how this window managed to leak in the first place but the water managed to travel through about 2" - 3" of sealant. Thanks and best regards, s/v Island Hunter
