Window Gaskits
Jim A
Has anyone replaced their window gaskit yet? I was wondering where to get them. Thanks Jim
E
Ed Schenck
Round rubber?
You do not say what make/model of "window". And are they the opening type? The round rubber gaskets that fit in the groove of the Bomar/Gray type portlights are available from Pompanette. Or used to be. :)
Steve Thorogood
Window Gaskets
Call the manufacturer direct. I did the same last year, and they supplied new "T" section rubbers as an up-grade to the original round "O"-rings. These can be purchased by the foot, and seem to work much better than the originals. Cleaning the old rubber out is a thankless task, but a rag with acetone and a small dowel helps. Once you have installed them, try wiping them down now and again with WD-40 or similar silicone-based lubricant. This seems to help them keep their resiliance, and extends their life. Good luck!
