Window Gaskets
Ron
I have recently purchased a 79 Cat 30. I have a few window leaks. As I have been removing these an recalking I noticed that the window gaskets are incorrectly installed. The inside of the gasket is on the outside and outside is in the inside so is collects water not shade and seal properly. The marine supply near by does carry these type gaskets. Does anyone know whom my have these gaskets? A note to anyone replacing gaskets, insure they are in correctly.
Catalina Portlight Replacement
Ron Try the association website, linked below. Other Catalina associations (www.C boat size.com) have good writeups, C27s are the best I think. Catalina Direct has great Catalina replacement parts for boats of your vintage. Stu
Ted
Beckson Port Seals
If you are referring to the opening ports, most on my 270 are Becksons (only 2 in main cabin are Lewmar) and new seals can be ordered direct from them at http://www.beckson.com/replace.html cost is ~$5.25, installation instructions are also on this page
