Talk to the Mfg
I'll warn you now, this is long...Bomar/Gray, which makes basically the exact replacement recommends 3M 5200 ONLY (I think that's still the case) for their windows. After installing 4 I have done almost everything wrong, and so can speak with some authority on how to do it right. DON'T USE SILICONE - trust me on this one.Selecting the windows - if you can find ones which match the *angle* of your cabin walls, water will drain better - mine are a little shallow, and I get a little water in after a rainstorm when I open the window because the gutters don't fully drain. I can't recall if this is an option though.1) Bomar/Gray (sailnet.com carries, btw) assumes you are mounting into a solid, cored sidewall. If your 30 is like mine, it's just the outer skin and the inner skin, no core. Hunter used aluminum T-nuts and stainless screws (good combo there eh?) so you'll find most of them rotted/frozen. But on the new windows you will find mounting holes on the inside portlight/trimplate, none on the outer - fairly useless...soI would fill in the old screwholes with epoxy/glass (I didn't and regret it). I think it would also be prudent to glass the 2 skins together (outer deck and liner) - that way water can't creep between the gap and leaks will be easier to trace. Before doing this, dry-fit the windows and make sure the fit is good - I had to deepen the gutter/runoff notches.The only problem with ditching the screw-holes is you lose any ability to clamp the window in place using the screws, and 5200 takes FOREVER to cure. More on this later.I think a good theory is that the goop on the outside of the window is really your seal and you don't worry about glue on the inner side - that way you won't trap water or disguise the location of the leak. You basically are using glue to seal the entire gap, and the trim-ring is just cosmetic so bear that in mind. Now place the new window in, and dry-fit (use a buddy) Tape (3m blue stuff) around the outside trim-ring (wide tape). Leave perhaps 1/8" gap between the tape and trimplate. Then also run tape around the inner window overhang. This allows you to use a generous amount of 5200 and still get a clean line when you pull the tape. Let the 5200 skin over pretty well before pulling the tape. You might have to cut it, but better than drips. I would also tape the outer face of the trim-plate (I find 5200 in my belly-button, ears, etc weeks later, so pays to be cautious).Remove the trimplate, goop 5200 generously (but not too much - you just want a little squeeze-out on both sides of the trim-plate. Place the window, place the trimplate, clamp as below...the portlight and trim-ring should 'float' in the goo - so don't clamp too tight.Ideas for clamping the inner portlight:1) Use the damn screwholes - then you have to fill them with something - stainless will cause rust-streaks, and bronze will cause green streaks - your choice. If you do this, maybe also cut some masonite/starboard to slide between the 2 hulls to provide a more-better grip for the screws. This is because there is a gap between the walls which the screws are going to try to close, potentially warping the sidewalls. 2) There is a sticky tar-like substance that auto-windshield installers use. Comes in a rope, and should provide a good bond to the inner hull liner. Might not be compatible with the plastic though.3) Build a jig which goes on the outer hull and provides enough room for you to work around. Basically a sheet of plywood with 4 legs, then a threaded rod leading to a smaller piece of plywood inside the window. Tighten nuts on the threaded rod to clamp the window in place, then apply a liberal amount of 5200 to the gap, place the trim-ring and go home for the night. 4) A really good and patient friend. You will need to rig, and prepare to empty, a foley/texas catheter, as well as provide a beer-bong.5) Turn the boat upside down and use sand-bags.6) Those adjustable shower-rods maybe...But now you have counter-sunk screw-holes on the inner window and nothing in them...Oh crap use the screws...it's only 12 more opportunities for each portlight to leak. Some might argue this makes the window stonger anyway (stronger than 5200? Hahahahahahahaha I laugh in their face)Oh, and the new plastic yellows much worse than the old stuff - so maybe count on painting the damn things after a year - probably with paint which is incompatible with the plastic...I wonder if those ones from newfoundmetals are any better...Anyone else?In any case...have fun.-Keith
