So the windlass draws up to 200a at 12v.
I'm thinking there are two ways to go here.
1. Put s 12v deep cycle battery forward under the vberth and charge from the usual system. This keeps the 'load' wiring smaller cause the battery is close by.
2. Use the house batteries, mounted in the engine room area, and put up with VERY large gauge wire running aft to the batteries.
With #1 I'll have to run some wires forward to charge that battery that lives under the vberth. Yes, it will be vented. That will also tie the battery for the windlass to the house batteries by virtue of the 'charging' wires.
With #2 I'll just bite the bullet and run the large gauge wire from the house batteries to the windlass.
Just looking for ideas here folks, thoughts?
Thanks,
Rich.
Thanks,
Rich.
