If you run your engine
it really doesn't matter, because the amps in from the alternator offset the windlass electrical load. You're putting in more than you take out. Anyway, you shouldn't be running your windlass without your engine running, because you should be moving the boat over the anchor with the engine, and not using the windlass to pull you there.I agree with Jon that it should be tied to the house bank, and kept separate from the start battery.Deep cycle house banks CAN withstand short heavy loads. In fact, many people ONLY keep their start batteries for emergencies, and deep cycle house banks can be used to start the engine normally. The start battery is there ONLY IF the house bank fails, so one school of thought says: normally start your engine with the house bank, and only use the start battery as a backup if you've spent too many days at anchor and have depleted your house bank (or for any other reason that the house bank is a goner).A lot of it has to do with how your boat is wired, too. Many have separated their start bank and wired it so that, unless the crossover switch is engaged, ONLY the start bank is connected to the engine starter, and only the house bank works the house loads. Especially in that case, I'd use the house bank. This is the three switch West Marine suggestion.We haven't done that separation and still use the 1-2-B switch. Most of the time I start the engine with the house bank, and leave it on 2 (my house bank). We have a combiner that combines the banks when charging (shorepower or alternator and solar). All charging devices are connected to the house bank PDP (positive distribution post), and the combiner charges the start battery. If I start on 1, the start battery, the charging goes to the house bank first, then through the combiner to the start bank, BUT the DC loads, like the fridge, instruments, lights if on, end up being drawn off the start battery (because the switch is on 1), and not the deep cycle house bank, which isn't too good for the start battery (although more's going in than is coming out). That's why some people make that 3 - switch modification to their wiring. One could also argue that the windlass on the deep cycle house bank is no different than the fridge on the start bank! Some people also put in a separate battery for just the windlass, sometimes for space and wiring reasons, but the life expectancy of any smaller bank is less than one larger bank, so it makes sense to maximize your house bank and run bigger wires to the windlass (if you physically can).StuPS - I also always agree with Gord ;D
