Pretty Straightforward
I completed installation of a Lewmar windlass in the past couple of days and the installation was fiddly but went without a hitch. The unit for the H33 comes with a gypsy and capstan and together with the controller, up and down foot switches and the reset breaker were all purchased through a chandlery designated by Lewmar. I also added a remote up/down switch in the cockpit and it hangs from the cockpit arch-console between the speakers. There was a five week wait for the windlass unit because it is in fact a Lewmar/Sprint 1000, modified specifically for the H33. I suggest thinking very, very carefully before installing any other unit than the Lewmar/Sprint unit that is specifically modified and recommended for the H33. The heavy (2 times 2GA) wiring harness was purchased directly from Hunter - which I highly recommend because there are other bits of wire in the kit and they are all cut exactly to length. Fishing the wires through conduits was trying at times but do-able. The real difficulty was getting the aft wiring up and through the arch, to the console. Wiring to the bow from the cabin was through a white plastic conduit located behind the starboard sofa, then through a black corrugated tube located behind the locker panels in the V-berth (remove the wood panelling) past the water tank, to the bow. The H33 comes with a windlass wire connection already in place from the DC panel ("WINDLASS" switch position) through a harness to the bow. This brown wire has a loose terminal at the bow end. The same harness also houses the bow lights. It is important to ensure there is a paper/cardboard template with the windlass kit to be certain the windlass is positioned correctly on the shelf in the anchor locker. That is important for two reasons 1/ so the capstan will fit in the round indented hole at the base of the anchor-locker trangular cover (you will have to cut out that hole with a 4 and 1/2" or 5" hole saw. I used the 4 and 1/2' saw and reamed out to finish) and 2/ that the chain has a direct route from the gypsy to the bow roller. Access to the bottom of the anchor locker shelf (which is re-inforced with inch ply and glassed over, is easily obtained by removing the access hatch at the head of the V-berth. Doing the job myself allowed me to get into the the innards of the boat and to understand the build and electrics a bit better. For me it is both good and not-so-good. Hunter is good with may things but pretty sloppy with others. All kinds of production crap had to be cleaned out from the areas that are not easily visible and in some cases the firbreglass work left a lot to be disired. However, the wiring routing is really neat and good quality stuff. The wiring and installation instructions provided by Lewmar was pretty straight-forward. Do it yourself - you will enjoy the project and you will also learn a lot about your boat.
